oil leak
Old Jun 30, 2004 | 05:45 PM
240kid's Avatar
oil leak
My car has leaked oil since i bought it and seems to be getting worse. When I go under to look for my leak i just end up quitting b/c it is hard to see where it is coming from. It seems to be on both sides above the oil pan (who knows maybe it leaks too) If it was coming from the pan could it splash upwards getting other things wet?? Seems to be around the pulleys but not above them at all and not the oil filter that leaks. like i said it is on the FRONT of my engine not sides or back. Any ideas on what it could be?? TIA
Nick
Old Jun 30, 2004 | 09:02 PM
Krazyballa3's Avatar
i have one too mines not that bad... front crankshaft seal?.... or some seal in the front... give it a role... i think thas my problem...tell me when you find out the leak... i need to fix mine too before it gets bad... mines a very minor leak...good luck
Old Jun 30, 2004 | 11:14 PM
LTSCUDRFT's Avatar
if your timing chain cover has ever come off it could of been reinstaled improperly... i didn't put enough gasket sealer on to mine, so it leaks where the oil pan and timing chain cover meet in the front and it is all over everything..
slidewithpride
Aug 12, 2011 09:51 AM
98cwitr
May 14, 2005 01:13 AM
Roscutoo
Feb 2, 2005 11:16 PM
sr20fan
Sep 24, 2003 07:05 AM
rudeboy
Sep 28, 2002 07:56 AM
