Power window help.
Old Jan 22, 2005 | 04:50 PM
dark_controller's Avatar
Power window help.
My window on the driver side doesnt work, when i push the button it just clicks. Any idea what is wrong?
Old Jan 22, 2005 | 06:25 PM
revolutionz_s13's Avatar
the window motor prolly just burnt out. Or check the fuse.
Old Jan 22, 2005 | 07:32 PM
jbask's Avatar
I had a broken wire. It broke beetween the door jam and the door. If thats your problem its a cheap easy fix!
Old Jan 23, 2005 | 07:05 PM
are there seperate fuses for the passenger and driver side windows?
Old Jan 25, 2005 | 09:33 PM
reefer1114's Avatar
i got the same problem. took off the door panel and when i press the button the gear spins but the window does not go up. anyone have a detailed diagram to fix this so i can save some dough and learn how to do it. thanks
Old Jan 25, 2005 | 09:34 PM
ill have to check and see if mine does the same thing.
Old Jan 31, 2005 | 07:33 AM
Amolao's Avatar
There is a wire rope that pulls the window up when the gears turn...the wire breaks and the gears just turns....very hard to fix, get another window actuator assy and replace the broken one....keep the original window motor for a spare just in case.....
Old Jan 31, 2005 | 08:09 AM
reefer1114's Avatar
yea i took the whole thing apart and figured out that one of the gears are broken so i got another assembly for $30
Old Jan 31, 2005 | 08:36 AM
Roscutoo's Avatar
That's why I hate power windows, just one more thing to worry about. But like reefer said, you can find the parts cheap. My girlfriend's power window stopped working in her Accord and the part was $300, so it could be worse.
Magius360
Mar 31, 2011 02:54 AM
Geno_110
Sep 19, 2003 01:23 PM
Monkey Boy
Aug 17, 2003 09:49 PM
SiNFuL
May 28, 2003 06:32 PM
S13Nissan240SX
Apr 22, 2003 02:59 PM
