Q45 injectors
Does anybody know if the Q45 370cc injectors are the same injectors as the stock SR injectors? Im looking into buying a set for my KA-T project and need to know if theyre the same before I buy them.
why dont you just buy aftermarket injectors probably easier to find and cheaper to
forums are over flowing with stock sr injectors. average price 120 bucks..
taken from another forum Side Feed Engine Style Size Impedance* Years / Models Nissan KA24DE Side feed 270cc High S13/S14 Nissan SR20DET Side feed 370cc High S13/S14 Nissan SR20DET Side feed 480cc High S15 Nissan RB25DET Side feed 370cc High R33/R34 Nissan VG30DETT Side feed 370cc High Z32 Infiniti VH45DE Side feed 370cc High All Years NOTE: 90 - 94 Z32 uses a style of injector that is non-compatable with KA fuel rails (still sidefeed), while 95 - 96 uses the same injector as the RB25DET and SR20DET, etc. Mazda FD Side feed 550cc High 93-98 Mazda FD Side feed 850cc High 93-98 Mazda 20B Side feed 550cc High JDM Mazda Cosmo? Subaru JDM STi Side feed 550cc (565cc?) High pre 99 Subaru STi Side feed 565cc High 03+ Toyota 7M-GTE Side feed 430cc (440cc?) Low Supra mk3 turbo Toyota 2JZ-GTE Side feed 550cc Low Supra mk4 turbo Toyota 3S-GTE Side feed 430cc (440cc?) Low MR2, 91+ Toyota 4A-GZE Side feed? 365cc Low MR2, MK1 Toyota Celica GTS Side feed? 310cc High 2000+ Toyota JDM 1JZ-GTE Side feed 430cc Low Chaser, Supra mk3? Toyota JDM 2JZ-GTE Side feed 430cc High?* Supra mk4 turbo Toyota JDM 7M-GTE Side feed 430cc Low Supra mk3 turbo note in order to run low impedance injectors. you must install one of the following resistor boxes obd0-1 preludes, obd0 civics, crxs, and integras, as well as g1 and g2 eclipses and talons |
(Post 306049)
Infiniti VH45DE Side feed 370cc High All Years |
go for it. The S15 injectors sound sexy Ry
yea i sold my sr injectors for 100 bucks a while ago..not hard to find
As sexy as the s15 injectors would be, they'd be overkill for a t25 (which is what im planning on running)
Dude T25? Project: Good Lordy 240! should run nothing less than a T28BB (S15 to match the sex injectors). Keep it real homie
im picking up STi injectors next week.
(Post 306161)
Subaru STi Side feed 565cc High 03+ more info taken from another forum ------------------ The following chart displays the maximum obtainable CRANKSHAFT horsepower vs. injector flow rate at 100% duty cycle, assuming a BSFC of .55 lbs./hp/hr. For Wankel and 2 stroke engines, multiply max hp in table by 0.9 to compensate for the higher BSFC of these engines. Injectors should be sized for 75-85% maximum duty cycle on engines used in constant high power applications such as race cars, aircraft and boats. http://www.sdsefi.com/ffhp.gif |
better get an afc..
Me?????????
I have always had safc and 550 is the limit.. great for me.. and yes to your question about the q45 injectors. |
(Post 306209)
Me?????????
oooohhh K. coolness.
