Question about the s13 silvia lights?
Old Sep 28, 2005 | 02:40 AM
240yoda's Avatar
Question Question about the s13 silvia lights?
I have a couple of questions about the s13 silvia lights?
1. are the fog lights supposed to turn on when the head lights turn on
2. if not then how are the fog lights supposed to be hooked up
3. can the headlight beam be adjusted
Old Sep 29, 2005 | 12:02 AM
1. no
2. OEM foglight switch or add your own
3. yes - look for 2 screws on the diagonal corners of each bulb (on the backside) but remember, Silvia headlights are RHD beam pattern
Old Sep 29, 2005 | 02:36 AM
240yoda's Avatar
your my hero bro thanks alot my headlights will no longer shine hard left thanks again
Old Sep 29, 2005 | 05:25 PM
240yoda's Avatar
is there a thread here that overviews the instal of the head lights the triple projecters to be exact i tried to search couldnt come across one
Old Sep 30, 2005 | 02:18 AM
Not sure about S13 Silvia thread, but IIRC unless you get the wiring harness for the headlights, all the plugs are different + there's 4 bulbs to power compared to the 2 on a stock, flip-up front end. If you're using your stock harness you're going to have to rewire to seperate the low and high beam sections. Also, one of the bulbs are H3C (the one you can't figure out if you check them, I think it's either high beam or center fog)
Old Oct 2, 2005 | 08:55 AM
naptime's Avatar
IIRC (goin from the top of my head and it's early in the mornin)bulbs for triple projectors
Lowbeam - H1
Highbeam - H3
Foglamp - H3c
And if you have the dual projectors,
Lowbeam - H3c
Highbeam - H3
Foglamp - H3c
team3d
Mar 13, 2005 03:01 PM
JonBrekke082885
May 17, 2004 07:43 PM
driftmania101
Aug 22, 2003 12:16 PM
ANOTHER_240sx
Jun 14, 2003 08:57 PM
weei2
May 3, 2003 02:54 AM
