Really Noisey
Really Noisey
How noisey are your cars? My 91 seems incredibly noisey. The engine noise seems very loud. I'm talking about the rushing sound of the engine. Are all the early 240's like that? It must be fan noise, should it be running all the time, it gets a lot louder as you accelerate. It's very irritating and I'm sure it wouldn't come from the factory that noisey.
check to see if your fan clutch is going bad... to test it the fan should turn with the motor off rather easy... and with the motor running you should be able to stop the fan... do not do this with your hand because if it is bad you will loose fingers... i would suggest turning the fan by hand to see if it moves freely... if it does then that is not the problem...
Flex-a-lite dual electric fans (scroll 1/2 ways for info)
http://www.pdm-racing.com/products/power.html
it might also be your alternator. Mine makes a sound like you were talking about, and fans aren't that loud where you can hear it on the highway or something, unless it is all kinds of messed up. anyways, take a long screwdriver and put it on the outside of the alternator while the engine is running, and then put your ear on the handle of the screwdriver. if you hear a grinding or it doesn't sound smooth, it is your alternator.
altima dual radiator fan acctually pulls more air through then those flex a lite fan for a lot more cheaper. freshalloy or zilvia has a long thread about this.
as for the truck motor acctually sounds like an airplane, its probably your clutch fan.
...dual flex-a-lites sound great, but theyre hella expensive from PDM. I was wondering, would i be able to get away with a good single fan? The duals are very pricey and pull a minimum of 20 amps.. and i know for a fact the stock alternator doesnt make 20 amps at idle, and factor in a big stereo and youre asking for a dead alternator.
get the dual FAL's
Single fan works to LA Phantom, i just have the stock single electric on my koyo and i've never had any problems.
I cant here my motor much, mostly exhaust, turbo and bov haha
