Seat...Bolt...Problem!
I installed my R32 seat a couple of months ago but now I have a problem on the mount that you have to mod. The bolt has become loose but for the life of me I can't get it out of the hole. You can grab it and just wiggle it around in all sorts of directions and even pull it up to a certain point but the bolt refuses to come out all the way so that I can put another bolt back in. I'm fed up with a rockin' horse seat! Any suggestions?
i had the same problem but with the seat beat bolt. i cut off the nut/head with a hack saw then just drilled into the bolt. using a bigger bit each time. that should get the bolt out. then just retap the hole.
yeaup... the bold has striped and no threads are present.. it pretty much to blank piece of metal now... you will have to use a pry bar while wrenching to get it out.. or do what 1993coupe said bro
uvamosk
Aug 12, 2005 07:31 PM
nissandrift
Oct 6, 2004 08:09 PM
