silicon gasket removal.
Old Sep 28, 2005 | 02:46 PM
zenkizen's Avatar
i'm changing the thermostat and the thermostat housing is "welded" together by the silicon. should i just use a heat gun to soften the silicon gasket or use brut force or any suggestions.
very minor problem. i know
Old Sep 28, 2005 | 03:01 PM
PNG's Avatar
PNG
A heat gun won't do much good - consider how hot that part gets on a routine basis, and the fact that even "normal" RTV silicone can take temperatures in excess of 600 degrees F in intermittent service.
Try tapping it gently with a rubber mallet from as many angles as possible. It will probably only take a couple of tries before it "pops" and comes loose.
Old Sep 28, 2005 | 03:36 PM
yeah, your just going to have to work with it until it comes off, shouldn't be too hard though, mine came off no problem
Old Sep 28, 2005 | 06:53 PM
Purple240's Avatar
Flat head Screwdriver.
Old Sep 28, 2005 | 08:02 PM
nsn240's Avatar
rubber mallet, flat head etc... then scrape it off and put the new one in
Old Sep 28, 2005 | 08:28 PM
TWong1200's Avatar
after you get it off, try one of these to remove the silicone.
Old Sep 28, 2005 | 08:31 PM
nsn240's Avatar
^exactly! i was too lazy to find a picture... dont scrape into the metal though
Old Sep 28, 2005 | 09:30 PM
PsYkHoTiC's Avatar
Welding torch. It'll take it right off!
Old Sep 28, 2005 | 11:38 PM
You're retarded
Old Sep 29, 2005 | 09:41 PM
zenkizen's Avatar
rubber mallet did fine, and i just used a razor to clean off the old silicon. it sucks that the reason my s14 was overheated wasn't the thermostat. it was a crack in the coolant hose. damn home depot hoses. =p J/K, kragen hooked it up for $11.99 but they wudn't take back the thermostat that i paid $6.99 for. yea i'm cheap but $6.99 can get u some mighty fine stickers. HA!
Old Sep 30, 2005 | 02:03 AM
Keep the new thermostat in there anyways since you took the old on e off already, and don't forget to bleed it well
Old Sep 30, 2005 | 12:28 PM
TWong1200's Avatar
and don't believe in that "take your thermostat out to make it run cooler" BS. Totally untrue.
Old Sep 30, 2005 | 02:53 PM
Hahah yeah the thermostat is there for an important reason lol
89180sx
Jul 15, 2003 01:57 PM
Monkey Force
May 31, 2003 01:00 AM
roadkill669
Apr 9, 2003 07:18 AM
konseiEva
Nov 9, 2002 02:23 PM
twofaze
Feb 10, 2002 07:09 AM
