squeeky clutch
Old Dec 24, 2003 | 06:34 AM
ProricanRacer's Avatar
squeeky clutch
Everytime I push in my clutch it squeeks....I was thinking about spraying some WD-40 up inside it and around the clutch but I wanna make sure that it is a safe and smart thing to do...
Old Dec 24, 2003 | 12:38 PM
Has been covered a few times, WD-40 will work or If you can put grease around all the moving parts of the clutch pedal.
Old Dec 25, 2003 | 06:20 PM
SLIDE OR DIE's Avatar
wow, I thought I was the only with this problem. I sprayed it with WD-40, it worked for a little bet but then it came back. now Im just like F*ck it and got used to it.
Old Dec 25, 2003 | 06:49 PM
The grease trick works better, or so it seems.
Old Dec 25, 2003 | 10:58 PM
ixcocoyxi's Avatar
let the wd40 sit for like 45 mintues.. it'll last longer..
Old Dec 26, 2003 | 02:32 PM
Grease trick has lasted for about 3 months now for me... I was referred by someone to try graphite powder (like what they use on bicycle chains) but since the grease trick is still holding up, take your pick
Old Dec 26, 2003 | 06:58 PM
ryan15's Avatar
lol.mine squeeks but I don`t here it cuz of my exhaust but it is pretty annoying when i start up my car.
Ryan
Old Dec 27, 2003 | 01:26 AM
WilloW's Avatar
Slap a gob of the automotive grease onto the spring and all the moving parts and you'll be good for a while. I had the same problem with my S14.
boricuajr
Oct 11, 2004 10:54 PM
haipho123
Jul 25, 2004 11:15 PM
cfin3
Apr 3, 2004 03:39 PM
Ray240CA18
Sep 18, 2003 09:58 AM
