sweet scored a wingless trunk
ok i got it painted dosnt looks so great but hopefully alot of wetsanding and ALOT of patience will help.
heres where i broke the third brake light lol
see the double sided tape
heres the top i sanded it a little
primered
here its painted blake looks like crap but im gona let it dry for a day or 2 then start wetsanding.
primered
It looks like you got some areas more than others. Mainly the lines / streaks on the main body of the lid. wet sand it with 800 grit and then prep for paint again. Try this technique:
Find out how thick the pain line will be.
After that, slowly "dust" over starting from one side to the other and back.
Then evenly match up your spray lines (the thickness of the spray) and "dust" the second line of paint.
Repeat until you go from top to bottom. It does not matter if it painted on properly or not, let what you have dry off a bit, say 10 - 15 min, then repeat those steps above. If you miss a few places, dont worry, let it dry off 10 - 15 min and "redraw" that line.
LOL dude, I just gave you the basic painting technique all body shops use LOL
cool ill try my best but i was running out of light so i hurried a bit ill try again tomorrow.
also im not to skilled with the rattle can so this will be a learning experiance thanks for the tips btw
yeah just wetsand that with 800 till it is really really smooth, then use a bunch of clear coat, let it dry for a few days, come back and wetsand again (this time with 1500 then 2000) then use an electric buffer with some "scratch-x" and wax. it should look very shiny
dcnism0
Mar 28, 2009 05:39 AM
