trunk lock??
Old Jul 8, 2006 | 05:31 PM
djradam's Avatar
trunk lock??
so, i was kind of wondering if the trunk had a separate key than the doors. it doesn't make sense, but I've bought 2 240s and both had trunk locks that didn't work (doors worked no problem). i tried cleaning them with lock stuff and nothing works.
reading the posts here it looks like people have problems with those locks ... do they tend to freeze often on the 240s ???
anyone have any good solutions?
thanks!
Old Jul 8, 2006 | 05:45 PM
carsonmnc's Avatar
I know mine is starting to freeze (S13).. But it definately uses the same key.
Old Jul 8, 2006 | 06:42 PM
re037's Avatar
what do mean as freeze? they dont close or wont open?
Old Jul 8, 2006 | 09:11 PM
djradam's Avatar
key won't turn at all. trunk opens by latch only.
it's wierd that it's happened on 2 models, so i didn't know if this was a common problem
Old Jul 8, 2006 | 09:58 PM
dak2007's Avatar
it's funny but the key i use to unlock my drivers side door and to start the motor won't unlock the passenger door or the trunk. i had a spare key made at wal*mart and it will open the passenger and the trunk but won't unlock the drivers side or start the car. it's weird.
Old Jul 8, 2006 | 10:12 PM
djradam's Avatar
hahaha, now that is a good one ... what the heck is up with that ...
Old Jul 9, 2006 | 01:56 AM
re037's Avatar
oh, i noticed my spare keys i had made did that too. what i did to fix it was i got a filer and defined the edges and ridges on the key more clearly. i guess 15 year old keys just loose their teeth after a while. a copy of something crappy will just be even crappier. kinda like making a photocopy of a photcopy.
Old Jul 27, 2006 | 05:30 PM
dopebox's Avatar
On my 95 se, the key will insert and turn the trunk lock, but the trunk won't open. It only opens with the interior release lever. Kind of a pain in the ***, but the trunk is so damn small I barely use it anyway!
Old Jul 29, 2006 | 03:40 PM
Darkvillin's Avatar
i had the same problem on my hatch. just take off the center tail light garnish spray some lubricant all over the lock. put the key into the lock and try to loosen it up a bit. it worked wonders for mine and its still loose as a goose. i used spray lithium grease. good luck.
positron
Aug 10, 2007 03:25 PM
battosaii930
Jan 16, 2007 09:12 PM
dak2007
Jun 3, 2006 08:48 PM
RealDS13
Nov 17, 2004 09:28 PM
SOUND2NR
Aug 29, 2002 04:08 PM
