Weak e-brake
Old May 1, 2006 | 07:49 PM
nixad's Avatar
Weak e-brake
Now from my understanding if i'm rolling down a street say 25mph and I pull my e brake as hard as I can that should lock the back wheels?
Now on my 89 240sx it simply slows the car as a weak brake, the only situation where I can slighty lock the rear wheels is when the weight is distributed toward the front of the car.
My question is, is there a way to tighten the e brake or will hte pads have to be replaced?
Old May 1, 2006 | 08:17 PM
ReigH's Avatar
theres a hole on the front bottom of the e-brake... pull the e-brake all the way up then tighten it...use a deep socket 10mm...
Old May 1, 2006 | 09:01 PM
g3bio's Avatar
wow i got the same issue. THanks
Old May 1, 2006 | 10:48 PM
dued's Avatar
Thumbs up
I had the same problem with my e-brake. I have tightened the bolt under the lever, and now the rear locks when I pull the brake up.
Old May 2, 2006 | 03:48 AM
Preston's Avatar
Sweet....same problem here, about to be fixed.
Old May 2, 2006 | 08:48 AM
nixad's Avatar
10mm, nailed it right on the head. thanks
Old May 2, 2006 | 11:39 AM
Preston's Avatar
Ok, I tightened that nut like a ****. The brake is tight as hell now, but still no lockage. Just hard as hell to pull and just a bit more stopage. I have new rear rotors and pads...how do I get it to lock up? I've only been trying straight, does it only lock when you pull it into a turn, or should it also lock it in a straight line? Thanks.
Old May 2, 2006 | 01:51 PM
nixad's Avatar
Its a brake not a lock, so my understanding was only in a turn.
I didn't want it to lock on straight aways just in corners and way, so tighting helped my situation (no serious test drive YET)
Old May 2, 2006 | 03:05 PM
barcode's Avatar
Is ur car an auto, I notice that in mine when I have it in drive and I yank up on the e-brake I get almost nothing, then when I do the same thing in neutral it locks those suckers up quick. Just something to think about.
dued's Avatar
Thumbs up
It should lock in a straight line also.
Old May 2, 2006 | 04:02 PM
nixad's Avatar
With a manual yes, becouse of the clutch with a automatic it shouldn't.
Old May 2, 2006 | 04:35 PM
Preston's Avatar
I got a manual...tightened the fluck out of it, and still no straight lock...so it should lock in neutral?
Old May 3, 2006 | 07:48 AM
ReigH's Avatar
your car rolls when you pull the e-brake up?
Old May 3, 2006 | 08:54 AM
Preston's Avatar
No it won't lock the wheels at speed like I'm trying to get it to go. It just slows the car down lol.
KeN VeRsUs RyU
Apr 4, 2006 03:00 AM
re037
Jan 2, 2006 03:45 AM
jdmsoarer
Apr 6, 2004 05:56 PM
SlydeSHO
Jan 22, 2004 04:20 AM
dkdeleon
Nov 14, 2002 11:33 AM
