weird sound when i go over 50mph
Old Jan 27, 2007 | 12:51 PM
anonymous_240's Avatar
anyways guys like the topic said everytime i go near or over 50 mph theres this weird tick sound that comes out of no where. it kinda sounds like im dragging something underneath my car but im not and first i thought it was my exhaust back firing or a tire blowing on me. so i pulled over and check nothing wrong. so i got scared that it might blow my motor or something lols because it sounds like something from the motor is about to blow too. so i just got off the freeway. sorry for such a lame explaination of my problem thats the best i can explain it.
Old Jan 27, 2007 | 05:57 PM
tehott240's Avatar
if its coming from the engine bay it may be throw out bearing if its a manual. or it could be your wheel bearings or loose lug nuts.
Old Jan 27, 2007 | 06:38 PM
cheack your lug nuts, i had the same thing happen last night. i thought a bearing was bad so i cheaked. fortunetly it was the lug nuts on the front driver side tire.
Old Jan 28, 2007 | 08:41 AM
oh! ok i'll check the lug nuts then. thanks alot i'll report back.
Old Jan 29, 2007 | 07:09 AM
its not the lug nuts they are all tight. but the bearings how do i check those?
Old Jan 29, 2007 | 08:57 AM
jack the car so the tire is in the air.
grab the tire from two oposite ends and try to wiggle it. (the tire that is)
move it wiggle it up and down amd left and right. if there is more movement than would seem to be normanl then something is wrong.
if could a bearing or some other suspention componant.
Old Jan 29, 2007 | 12:24 PM
eomund's Avatar
When the throwout starts going bad usually you here a hummin or whistleing type noise. A little trick to checking if that's it is if you get your car up to the speed it makes the noise and slightly depress the clutch, the sound goes away.
Being as it does it at a certain speed, not a certain RPM would lead me to believe it's something to do with the tranny and back. Do you have anywhere that has like a dino tester or smoething where you can get the wheels to that speed and you can walk around the car while it's doing it?
Old Jan 29, 2007 | 07:45 PM
a dyno? hmm...im not sure if my cousins shop has one but i can try it there if they have one. if not i guess i'll take it the shop that fixed my car two weeks ago...
jpmopfl
Jan 27, 2008 03:21 PM
loafmaster
Sep 12, 2004 12:09 PM
kaos
Dec 10, 2002 04:21 PM
Driftin180SX
Nov 12, 2002 05:04 AM
Andre576
Feb 7, 2002 10:11 PM
