what to do first?
what to do first?
Hello, im about to buy a 89-94 240sx to make into a track project car. I would like to ask the pros around here what are some of the basic things to get before starting to really mod the car?
I was told to replace bushings, because these old models tend to have them in bad condition.. should i just do suspension, or also mounts, is there a company that sells a kit?
Also ofcourse the routine oil change, oil filter, spark plugs, wires, anything else?
I was also told something about putting a spacer in the rear xmember, because those bushings tend to brake and give traction problems.. do they and is this spacer thing a good idea?
Any thing else that springs to mind?
Thanks in advance to all!
if you are going to make it a track car then i would suggest adjustable tc rods and not just the bushings in the front... gives you more control and adjustment of the front suspention... then i would go with stronger control arms as well as full suspention/coilovers...out back camber correction kits and the collars as well as all other bushings... energy suspention makes a complete kit for the 240...
