What i must check when i just bought a 1990 240sx
Old Nov 22, 2003 | 07:29 AM
Bernigts's Avatar
Well the topic says it!
I just bought a 1990 240sx of 240 000km (engine was rebuild like 50 000km)
I already the alternator to change but that all of it...is there anything i must take a particular attention to be safe of road ?
Thanks for you help guys!
Old Nov 22, 2003 | 09:03 AM
drnovascotia's Avatar
when it was rebuilt did they put in a new water pump & thermostat? thats something you'll need to know. Other than that, check for normal replacement stuff, see if the plugs & wires have been done recently, fuel filter, o2 sensor, clean the mafs, air filter. Other than that you should be good. Tie rod ends are quick to go out on s13's, check your outer tie rod ends. Other than that I reckon you should be good to go! Any problems needing adressed?
Dr.
Old Nov 23, 2003 | 07:32 PM
OverBoost's Avatar
just to add to what the Dr. said, you might also want to check your radiator and coolant hoses since those are a commonly replaced item on 240s. we wouldnt want your new 240 overheating, now would we
Old Nov 24, 2003 | 05:31 AM
this isn't mechanically-related, but run it through a carwash and check for leaks, especially if you have a hatch or if it has a sunroof. My friend's 92 hatch had a water leak in the sunroof at the exact place where the dripping water would fall on his face... not good if it's rainy outside and very dangerous. He also had water coming into the hatch on the right side (fixed with silicone) but if that wasn't caught, eventually his car probably would have smelled like a fish tank.
On the mechanical side, I think Doc forgot to mention a timing check. BTW when did you get Moderator honors, Doc? GJ
Old Nov 24, 2003 | 06:45 AM
yeah, I didn't mention a timing check because I don't know how yet, lol.
And they gave mod status to hyjnx and I because between both of us we're on 24/7. It's a bit of work but so far so good. Mainly i've just been moving posts to the FAQ section.
Dr.
Old Nov 24, 2003 | 10:07 AM
Yep yep, and they also made S13 a mod. But back on to topic hehe
Old Nov 24, 2003 | 12:55 PM
BeteNoir's Avatar
Also make sure that the brake calipers arent leaking. And shift up and down through all the gears to check out the syncros. I usually will go with a 1/2 inch ratchet so I can check the oil levels in the tranny and diff. And if he argues that he won't let you then you can whack him with it.
Old Nov 25, 2003 | 06:20 AM
Bernigts's Avatar
Thanks alots for all the info...Thursday i will go get the 240...i will check all of that and replace it if needed to..
I can't wait anymore to feel how a 240sx is....lol i didn't drive it yet lol...
I hope the 152lbs of torque will be fun to drive!
Old Nov 28, 2003 | 07:07 AM
mafaqinballs's Avatar
Check the fuel injectors, mine leaked
Old Nov 28, 2003 | 04:02 PM
yeah, check for the smell of fuel, the o-rings going bad are not very common, but it's been heard of happening.
Dr.
priest19843
Nov 7, 2008 09:53 AM
240hooah
Apr 25, 2004 07:03 PM
Bahraini240sx
Feb 1, 2004 10:44 AM
Chicagboy
Aug 30, 2003 08:43 AM
Jizmo
Jul 29, 2003 09:34 AM
