What jack and stand should I get for swap?
Old Sep 1, 2005 | 05:45 PM
h22lude's Avatar
I don't know if this is in the right section so if not, you can move it.
What is a good jack to get for auto work. I am looking at one similar to this but the one I am looking at has a bigger lifting plate.
http://www.sears.com/sr/javasr/produ...Lift+Equipment
Or I was looking at this jack.
Also, what jack stands would I need? How high do I need to car to be? I am looking at ones that have a max height of 21 inches.
Old Sep 1, 2005 | 06:32 PM
nsn240's Avatar
#2 cause its small, convient and easy to use...#3 cause they are cheap, safe and effective
Old Sep 1, 2005 | 06:55 PM
h22lude's Avatar
The jack I am looking at is the same length as the second one. It costs $70. The 2nd one is $200. Is it worth an extra $130?
Old Sep 1, 2005 | 08:16 PM
nsn240's Avatar
probably... there's gotta be something differnt between them. Wether its quality of material, lifting capabilty w/e
Old Sep 2, 2005 | 04:56 AM
eh...I just have some generic ****, works good for me
moved to "General"
Old Sep 2, 2005 | 06:59 AM
shotty53's Avatar
i work for sears so i know some **** on it... when i go in, ill look into further detail
for now, the red ones is aluminum (a lot lighter) and has a bigger lift base. the black one is steel reinforced and can lift more weight.
and knowing sears, you will have a better warranty with the red one
Old Sep 2, 2005 | 09:32 PM
h22lude's Avatar
Shotty, tomorrow I will get the part numbers for you.
Old Sep 3, 2005 | 04:11 AM
shotty53's Avatar
dont worry i know the part numbers... lol
u should purchased it last month, we had a special, buy the $50 jack and get 2 stands free..
Old Sep 3, 2005 | 06:02 AM
h22lude's Avatar
They still have a deal with the first one I posted but not with the one I want. The one I want isn't on the website.
The jack I am looking at in the store is also in the catalog. It has a part number of 0950186. In the catalog that also comes with 2 3-ton jack stands.
There is also another one like the $200 I posted. But it only lifts 3000lbs. I guess that is ok because I won't be lifting the whole car at once.
Old Sep 3, 2005 | 10:20 PM
nsn240's Avatar
just get a cheap jack and 2 stands... easy, cheap and safe, i shoulda said that before, but i overthunk it
Old Sep 4, 2005 | 04:43 AM
if you are going to lower your vehicle or put on aero you may also want to look for a low profile jack
Old Sep 4, 2005 | 04:17 PM
h22lude's Avatar
^^^ I was thinking that but it would be cheaper to make wood steps to drive on and then jack it.
Where can I get a low profile jack?
Old Sep 4, 2005 | 04:29 PM
Save your money with Wal-Mart jacks. Heck use the oem jack that comes with your car if you have to.
yarou
Apr 24, 2007 09:33 PM
KeN VeRsUs RyU
May 19, 2005 03:24 PM
s13slider44
Jan 8, 2005 10:02 PM
SpdElemts
Sep 24, 2004 09:53 PM
impact_grn_yosh
Oct 28, 2003 11:40 PM
