what kind of oil/oil filter do you use?
Old Jan 31, 2006 | 12:29 AM
phadedj's Avatar
Bosch Filter - Royal Purple...
I'd say if you're going to throw the little extra money on anything in your car, be sure to get high grade oil/filters... it's the blood of the car. Why go cheap on [in my opinion] the most critical part of your car! - I say that because with proper cooling your engine will last a lot longer, and some of the cheaper oils leave deposits etc.
Old Aug 7, 2006 | 10:27 AM
xvtxboi508x's Avatar
is it 10-30 for summer 5-30 for winter?
Old Aug 7, 2006 | 11:18 AM
anonymous_240's Avatar
i use k&n and castrol gtx but ima go mobile one...
Old Aug 7, 2006 | 11:42 PM
phreze's Avatar
oem and royal purple FTW! Gonna try out the power enterrise or greddy unit to see how they work.
Old Aug 8, 2006 | 09:32 PM
Darkvillin's Avatar
like someone said earlier, is it worth it to switch to say mobile 1 synthetic if you ka has lots of mileage? and is it better to run thinner or thicker oil on an older engine?
Old Aug 10, 2006 | 05:44 PM
djw46810's Avatar
If you have been using regular oil for the life of your car, itd be a good bet to keep on using regular oil. Gaskets and seals well swell a certain way due to the impurities of regular oil, and putting in synthetic in an old car can cause these seals to change and leak oil.
So it would probably be your best bet to use a decent conventional oil such as castrol gtx or pennzoil. I would stay away from cheap oils suxh as wal-mart brand, due to them not being refined as well as better oils.
Old Aug 10, 2006 | 05:50 PM
BigVinnie's Avatar
Castrol 10w40, and fram filter
Old Aug 11, 2006 | 01:23 AM
NcTwOfOuRtY's Avatar
royal purple/k&n filter represent
Limited Slippin
Mar 17, 2016 09:27 AM
BILLYhoang
Mar 17, 2008 08:51 AM
motegineon
Nov 29, 2005 04:23 PM
S13freak
Apr 2, 2004 04:58 PM
SlydeSHO
Jan 30, 2004 10:43 PM
