Why switch motors?
Originally posted by motegineon
lol then why are you building an NA KA24e??
hahaha its only NA for now...it shall be turbo soon enough...probably T25 cuz im poor. but it should be fun with turbo and ITBs.
well i chose the single cam because im poor and it was free and yes i will be enclosing the ITBs in a plenum even when i run them without a turbo so i can use the stock ecu and maf.
as for running turbo and ITBs in conjunction on a KA engine has been done.
http://www.zilvia.net/f/showthread.p...&highlight=ITB
^ that is frickin sex in a box!
theres a few people that have it, there is actually a kit for the sr20 that makes them bolt right up to intercooler..
as for making an NA powerful basically you do full boltons ie. intake/header/exhaust/pulleys/ecu/tune/cams/clutch/flywheel and then of course you can strip the car, get lighter driveshaft, and other things like that.. upping the compression is key, basically you want high compression rings/pistons...and ITB's of course but they are more for throttle response.
yuta, if you want to do t25 i have smic piping and a spare turbo and stuff. let me know if you ever need it
#27
Originally posted by ryguy
Is an SR swap really gonna cost 5 grand? The motor should be give or take 2 grand. If you do it yourself, after all the costs, shouldnt it run you like 2500?
#30
Originally posted by RuizXIII
IMO 240's are overated, if you want a real car get a Ford Festiva
sr20 i think is just lighter and could hold more power on its own.. i dont feel like getting into it right now
