Wire Short
Old Mar 26, 2008 | 04:03 PM
crazydrifter's Avatar
Wire Short
Well today I put my starter back in and tried to start my car smoke started coming from the ecu so jumped out of the car and disconected the bat. I went to look at the the ecu expecting the worse but it looks like a wire short and the wire didnt even go to the ecu.
http://i280.photobucket.com/albums/k.../IMG_19991.jpg
the blue arrow is the wire from the harness that goes past the ecu to the wire by the red arrow, i need to know where the black wire goes in the engine bay(I think its a ground but not sure).
Thanks
Old Mar 27, 2008 | 11:26 AM
ConceptS14's Avatar
well that all depends on where the wire is comming from
you have a picture of a black wire on the floor of your car.
Old Mar 27, 2008 | 11:51 AM
Its from the main wiring harness that goes through the wire wall to the ecu, and its the only black wire that goes from the engine bay(in the harness) past the ecu. I need to know where it is coming from or where it goes.
Thanks
Old Mar 27, 2008 | 12:54 PM
ConceptS14's Avatar
when i say "where the wire is comming from" i mean to say, what is the other end of that wire attached to?
as a ground wire, it's either attached to a ground already and you need to attach the free end to a component to supply a ground to that component.
if it is attached to a component already, then you just need to attach the lose end to a grounding point.
Old Mar 27, 2008 | 01:15 PM
Im sorry maybe I worded it wrong but thats what i wanted to know, what the other end of the wire is attached to. I dont know if it is a ground or if its something else.
Old Mar 28, 2008 | 10:02 AM
ConceptS14's Avatar
you're just going to have to trace the wire back.
you cant possibly expect anyone to tell you where a black wire sitting on your floor is comming from.
Old Mar 28, 2008 | 10:14 AM
well i think its a ground on the intake manifold just thought someone might have known, im just confused about why all of a sudden this happen
zilvia14
May 21, 2004 11:56 AM
bgbowlerfreak
Jun 21, 2003 09:25 PM
DCTperformance
Feb 4, 2003 11:39 AM
RUTH'LESSDET
Oct 19, 2002 10:51 AM
spitz7985
Sep 6, 2002 06:45 AM
