Wiring stock tach so rpm's work..
Here is a good one....
I have heard from the grape vines that when you do a sr20 swap, there is a way on how to wire from the ecu so the rpm's work on the stock tach.
Has anyone else heard this and how would it be done?
Thanks everyone...
Thanks everyone...
ah, my bad man...
it shoudl work still though because its an s13 to an s13. did you do the wiring yourself?
i do have a ecu pin out diagram if that would help
email me if you need it. ill send it to you right now
Originally posted by 240-Silvia-240
I thought s13 were from 1991 and up. I think the ca18 engines were in the 89-90 models, or I'm I wrong on that??
89-90 had the SOHC KA24E
91-94 had the DOHC KA24DE
"1989-1990: S13 Silvia (240SX Coupe) - 175hp DOHC I4 Turbo (CA18DET)*
1991-1993: 180SX (240SX HB) / S13 Silvia (240SX Coupe) - 205hp DOHC I4 Turbo (SR20DET Redtop)*
1994-1996: 180SX (240SX HB) - 225hp DOHC I4 Turbo (SR20DET Blacktop (S13))*
1995-1996: S14 Silvia Coupe (240SX Coupe) - 250hp DOHC I4 Turbo (SR20DET blacktop (S14))*
1997-1998: S14 Silvia Coupe M/C (240SX Coupe M/C) - 250hp DOHC I4 Turbo (SR20DET Blacktop (S14))*
1999-Present: S15 Silvia Coupe - 280hp DOHC I4 Turbo (SR20DET Blacktop (S15))*
*Denotes the top models. Silvia's come in Jack, Queens and Kings models (J's, Q's, K's). All power figures and motor types are in the K's cars."
got this from http://northwestnissans.com/board/showthread.php?t=4204
