Free HP/ Cheap HP
Old May 29, 2008 | 02:13 PM
  #31
james_240nismo's Avatar
well as far as those eletric superchargers go it was a good idea but not enginereed properly. a turbo still blows if you put your hand over the output .the bov are there to keep you from droping valves. you'd be beter of just stiking a modified vacuume cleaner in reverse in your intake that like the turbo still blows if you try to pug it.
Old Jun 9, 2008 | 10:22 PM
  #32
bucket240's Avatar
^^^HUH.... "hand over the output"??? "dropping valves"??? "pug it"??? Dude you lost me.
Old Sep 23, 2008 | 05:45 PM
  #33
all4sr's's Avatar
i've seen three sites that claim that for every 17lbs-19lbs you "gain" 1hp.
its true, and ive done it, its more like every 20lbs though.
I removed the ac/ps, Heater core, i took the the ENTIRE interior out and removed ALL the sound deadining and repainted it, the sound deadining alone all together was something like 55lbs. if i remember correctly, i also removed all the interior minus the front seats, dash, and front carpet, i was very disappointed with the dyno numbers that my car was making(it was like 210hp with the CA, ill try and find the DYNO sheet), so i did all that and took it back just to see and i got like 6 extra HP....
p.s.....having a friend who manages a shop with a dyno is a plus
p.s.s.....sr's and rb's boss
Old Sep 23, 2008 | 06:00 PM
  #34
FuriousZ's Avatar
Removing weight is not going to make the car produce more horse power.
Its going to make it lighter and quicker of the line reducing the weight to power ratio.
Old Sep 23, 2008 | 06:12 PM
  #35
true unless you're reducing rotational mass. the back seat is not rotational mass however.
Old Sep 24, 2008 | 04:00 PM
  #36
NiSmO Knight's Avatar
To my knowledge (in theory) is that shaving off 10 lbs off a car is better than gaining 1 (one) hp or producing an extra hp.
Yes, its all about power to weight ratio!
Old Sep 24, 2008 | 08:34 PM
  #37
Rotary_tech's Avatar
Lightly tuned SR powered S13 at 240hp>400hp GTO
Old Sep 24, 2008 | 08:54 PM
  #38
but comes nowhere near the gto when comparing awesomeness.
Old Sep 24, 2008 | 09:50 PM
  #39
fadedsilvia's Avatar
hell yea on the power to weight ratio, and your not actually producing more hp when u remove ur a/c and p/s or rotational (unsprung) weight, the hp is already there, your just using it for sumthing else now instead of turning a pump ect ect... for instance, to the wheels for a hardcore burnout session
Old Sep 24, 2008 | 10:49 PM
  #40
yes the hp is already there but that's why we have terms such as whp, chp/bhp
Old Sep 24, 2008 | 11:07 PM
  #41
yes, indeed
Old Oct 1, 2008 | 09:11 AM
  #42
240smoke's Avatar
advance timing and use premium gas. eliminate ac, use electric fan and weight reduce as much as possible.
Old Jun 3, 2009 | 10:12 AM
  #43
bump for new user
Old Jun 3, 2009 | 10:50 PM
  #44
deputydawg's Avatar
i've been told that deleteing the egr will give you about 8 hp, what about going to an electric fan? how much will that give me?
Old Jun 3, 2009 | 10:57 PM
  #45
none.
