Lights come up wont go down
Old Nov 18, 2007 | 06:25 AM
Whattup32526's Avatar
My headlights come up but dont seem to want to go down unless I turn them down manually....what should i check ? All relays and fuses are good already changed them....could it be the headlight timer?? on the drivers side around the fuse panel?? anything you got let me know thanks
Old Nov 18, 2007 | 09:39 AM
onikyan's Avatar
i had a couple that did that to me. one turned out to be the fuse and relay panel on the driver's (left) side. the other turned out to be the actual headlight switch that's on the steering column. if you're good with a multi-meter then you can track it down quick with that, if not then it's all trial and error with replacing parts here and there. good luck with it though
Old Nov 18, 2007 | 02:50 PM
Drift Motion's Avatar
does the headlight button work?
Old Nov 25, 2007 | 07:14 PM
g3bio's Avatar
i fixed this problem today actually it was a fuse that was under the hood in the box beside the coolant tank. not the small fuses one of those square long fuses.
you said it was not going down but usually for saftey reasons the headlights go up when a fuse is blown double check that and make sure its a brown 25 amp fuse with a clear top, you dont even have to pull it out.
Now when you install it make sure that the lights are on when you put the fuse in (and up) otherwise it might blow again,,, thats what happend to me today dont ask me why my buddy just told me to do it and it worked.
hope that help.,s
Old Nov 25, 2007 | 08:11 PM
Yeah check the fuses. Those headlamps can be a real pain.
Old Nov 25, 2007 | 08:21 PM
cool ill check it first think in the am....i start a new job tommorow... yay!!
SHIFT_Sideways
Jan 1, 2006 03:37 PM
Ghettostamps
Sep 12, 2005 12:29 AM
sidious_14
May 27, 2005 05:26 PM
Dres240
Mar 3, 2004 10:32 AM
Sizzzoooo
Feb 23, 2002 04:42 PM
