n60 maf install?
Old Jan 17, 2007 | 03:23 PM
SRdeals's Avatar
Unhappy n60 maf install?
i just got an n60 maf today from the junkyard for $0.00 and i need some info on how to install it. i have searched my *** off and cant find what i need any help will help (duh). i am wondering how my KA will run will run after this install too.
Old Jan 17, 2007 | 05:30 PM
Re: n60 maf install?
HAHAHA
it will run like *** unless you get an afc and plug in the in and out settings.... but its still going to run the same or worse than stock man. just sell it. you can't just plop a new maf on a motor and expect it to work well without additional supporting mods (ecu tune, larger injectors etc.) wiring is the same as the z32 mafs, wiring instructions are on the jwt site.
Old Jan 17, 2007 | 09:07 PM
SRdeals's Avatar
HAHAHA.... ......yur wrong.
just installed the n60 using guide from jim wolf technology- it idles a LITTLE bit higher (100rpm.) and gives some more airflow. as for the bad, well i now have three less butt connectors in my toolbox and one more thing to rattle off when someone asks me what i have done to my car. - also i now have an MAF that will serve me better in the future when i further modify that car.
Old Jan 18, 2007 | 09:40 AM
okay it idles higher, but that doesn't have anything to do with how the air/fuel mixture looks under different loads. the n60 mafs is going to allow more unmetered air to get into the motor creating a very lean air to fuel ratio under normal driving, and wot you will probably experience a fair bit of detonation.
Old Jan 18, 2007 | 07:15 PM
SRdeals's Avatar
where could i get an afc to plug into this maf? and how lean is it probably running right now?
Old Jan 18, 2007 | 07:45 PM
probably about 20-30% leaner
afc like apexi safc 1 or 2 or neo. ebay, forums etc. just set the in and out settings and it will convert the voltage reading for the ecu. the settings are probably availible on ka-t.org somewhere
Old Dec 11, 2008 | 06:43 PM
sav180's Avatar
now would you need to add more fuel since he added more air because of the n60 maF??i jus added mine along with 370cc sr inj and a xcessive mani..u think i would need to add more fuel??
Old Dec 11, 2008 | 07:06 PM
the Maf hooks just like z32
Old Dec 11, 2008 | 07:28 PM
sav180's Avatar
ok
Old Dec 11, 2008 | 07:35 PM
its not as simple as just adding fuel. you need a wideband and a dyno and or a long stretch of road where cops dont exist.
Old Dec 11, 2008 | 07:37 PM
sav180's Avatar
im tryin 2 get a basic set up so i can drive it..i ben searchin for over a month...im dyin here with out my car..lol...its like it doesnt make enough power to even put it in gear so i can test drive it n tune a lil
Old Dec 13, 2008 | 05:49 AM
check out the safc thread.. there are preset setting in there.. just find one that is close to your setup... its not recommended, but it will get you moving.
!!!!!!!!!!!!make sure your In and out settings are Correct!!!!!!!!!
Biggamehit
Mar 16, 2009 07:14 AM
hatrick6
Dec 24, 2008 09:04 PM
Treyz
Feb 17, 2008 05:59 PM
chicagos14t
Jan 10, 2007 05:36 PM
