Over Heating HELP!!!
Old Jul 9, 2007 | 02:48 AM
91240SXGuy's Avatar
My ride's over heating. I drained the radiator & I'm replacing the upper & lower hoses today & filling it with new antifreeze plus water wetter. I'm hoping this does the trick, but any other input/advise would be great. BTW I have an aftermarket temp gauge so I can see a pretty accurate temp.
THANX! Peace...
Old Jul 9, 2007 | 12:09 PM
Be sure you bleed it thoroughly, also check to see if you thermostat is working correctly.
Old Jul 9, 2007 | 12:49 PM
positron's Avatar
Friend of mine had a bad radiator cap that wasn't sealing properly.
Old Jul 9, 2007 | 06:01 PM
91240SXGuy's Avatar
Also taken care of...new cap.
I found the problem...there was a small plug in the raditor. I flushed it severeal times. Finally filled with coolant & water wetter...runs like it did before. Thank guys so much for your advice/tips.
Peace!!!
Jay_240sx
Nov 20, 2007 11:00 PM
91240SXGuy
Aug 9, 2007 05:11 AM
Komedy
Jan 23, 2007 05:37 PM
godasian
Sep 19, 2005 08:21 PM
NissanPower s14
Mar 4, 2005 11:54 AM
