How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Rear Sway Bar Install Pics...for the Noobs!!!
Old Mar 31, 2007 | 01:20 PM
positron's Avatar
I took my stock swaybar off a couple of weeks ago when I installed some subframe spacers. The bushings were shot and one of the endlinks was bent so I got a new set of Energy Suspension D-bracket bushings and they came with some new swaybar endlink bushings. I was initially just going to upgrade to a bigger set of swaybars but since my front swaybar was incomplete(missing an endlink) and the rear had bad bushings and endlinks, I decided to just buy some new bushings and try the stock bars out at a couple of autocrosses and see how I like them at their full potential before deciding if I needed something better at my current skill level.
Tools needed-
Jackstands
Jack
Socket wrench
15mm socket
14mm wrench
Socket extension
Torque wrench
Here's the Energy Suspension bushing set, the new endlink with bushings and the old endlink.
Note the bent endlink
First thing you need to do is lube the swaybar and the D-bracket bushings up with the provided grease and slide them onto the swaybar.
Here's the new swaybar D-bracket bushing with the old bracket bushing. It was pretty soft compared to the new one.
Here's my stock swaybar(15mm yeah it's tiny). When I took it off it was all gunked up with grime so I cleaned it and gave it a fresh coat of black along with my D-brackets. They weren't bent so I re-used them.
First thing you do is of course jack up the car and place your jackstands under it.
Take the swaybar and slide it under the back of the car over the exhaust and just under the rear of the differential.
From there you take the swaybar and slide it forward to where the mounting points are.
Next, take the D-bracket and place it on the bushing...don't bolt them in yet but go ahead and slide them left or right to line them up with the mounting points.
Now you put the endlinks together in this order...washer-bushing-swaybar-bushing-washer-separator-washer-bushing-lower control arm-bushing-washer-top nut. It's like making a samich!
Next you tighten the link up with the 15mm socket for the top nut and use the 14mm wrench to keep it from spinning on the bottom.
Torque the links to 78-104ft. lbs.
Finished. Repeat on the other side.
Now you can tighten the D-bracket bolts down and torque them to 32-41ft. lbs.
Torque wrench
Done!
File Type: jpg
Old Apr 16, 2007 | 09:42 PM
once again great pics and write up , thanks you
Old Apr 19, 2007 | 11:34 AM
ZeroOath's Avatar
nice job man
2fourDS14
Jul 2, 2008 02:26 AM
positron
Jun 25, 2007 11:44 AM
Carparthookup
Oct 9, 2005 06:35 PM
futureteg
May 26, 2005 11:10 PM
Gr3En
Jun 29, 2004 09:42 PM
