1995 Gas in Oil..Help
I bought a '95 240 about a month ago. I changed the oil about 3 weeks ago and today when I checked it not only did it rise about 3/4" past the high mark but it also has the smell of gas. Both after the oil change and today the car had been sitting overnight when I checked it. And it does not seem to be running rich. I checked the spark plugs and the tips look good (no wet fuel on them except on the threads). I got a scan tool and checked the codes and P0325 (Knock Sensor) showed up. I don't know if this could contribute to the gas or not. Where should I start with the diagnosing of the gas in the oil? Any help would be greatly appreciated.
Knock sensor means the Ignition timing is off.
or...l.. I would geuss either a bad head gasket, faulty injector or a bad fuel pressure regulator.
EDIT : Also, if you have the tools, do a Compression test.
I was worried it might be the rings but thought if the rings were shot that oil would get into the gas and cause blue exhaust smoke (which I don't have). If it is the rings about how much do you think it would cost to fix the problem?
ass15
Dec 17, 2004 12:15 AM
