240sx Engine Missing
Old Dec 11, 2005 | 03:38 PM
super_240's Avatar
Okay My old 240 which im probably gonna be buying back.The engine is missing alot to where it stutters and sounds like its about to shut off, i was guessing it was probably the spark plugs or wires or something and easy fixer .do you guys think it would be the spark plugs or spark plug wires?
Old Dec 11, 2005 | 03:50 PM
mv520's Avatar
Check the timing. get a timing light
Old Dec 11, 2005 | 05:25 PM
Ron Smith's Avatar
You need an ohm meter to check the wires for the correct resistance. Plugs? Maybe. Are they the right type and gapped properly?Those would be the easy things to check. Could be throttle body and a whole bunch of other things. Try to get a hold of a repair manual and start by searching in the troubleshooting section. Vacume leaks, timing just a few more things. Good luck
Old Dec 11, 2005 | 06:05 PM
BigVinnie's Avatar
If the sputtering occurs within idle it could be your IACV (Idle Air Control Valve). The ecu doesn't throw codes on it necesarrily so it is kind of hard to tell if that could be the case. Make shure all your electrical is good first. Then use carb cleaner to try and clean the IACV.
If it isn't that then check your fuel pressure.
Old Dec 11, 2005 | 08:00 PM
super_240's Avatar
Well when i had it before the vacum line kept d/c so that might be what it is im gonna go look at it and all and see if thats it if not im gonna take it to a friend of mine whos a mechanic he should be able to tell me whats wrong with it
l2aine
Jun 7, 2004 01:19 AM
mango02
Jun 4, 2004 09:12 PM
gerbort
May 21, 2004 11:59 AM
irax
Dec 23, 2003 06:04 AM
kaos
Feb 10, 2003 02:05 PM
