90 240sx starting issues
Old May 19, 2007 | 11:47 AM
MaximJ's Avatar
Angry 90 240sx starting issues
Every time i start the car - the RPMs dont go higher then 400-500 and the whole car shakes until ill floor it then it runs and idling just fine. Today its got even worst, it starts from the first try and immediately dies. I start it second time and its all good. Im thinking either MAF or fuel pressure regulator i think it just doesn't hold the fuel in lines over night while the car is off and the fuel goes back to the tank so what yall think?
Old May 19, 2007 | 11:57 AM
i think your on the right track you might also check the injectors
Old May 19, 2007 | 12:05 PM
MaximJ's Avatar
injectors are fine at least they don't leak i don't really know what to start with? any other ideas?
Old May 19, 2007 | 01:30 PM
a clogged or open injector can keep the engine from firing up or flood it.
if you can get the car started again and it stays on take flat heat screw driver put in on the injector and put your ear to the top of the screw driver.
you should hear it clicking. do it to all four, if the clicking is the same for all 4 move on to something else.
Old May 19, 2007 | 08:28 PM
MaximJ's Avatar
iight ill do that boss hope they are fine. thanks ill post another reply sometime soon tho to say if they click or not or watever
dcwiker05
Sep 1, 2009 09:57 PM
plat
Aug 20, 2009 11:01 PM
J90lude
Jul 9, 2009 06:27 PM
ryan240sx
Jun 24, 2005 07:07 PM
Griffin
Feb 12, 2003 12:56 PM
