'95 ka24de in a 89 hb
Old Jan 15, 2003 | 12:12 AM
morexviit's Avatar
would this be a direct bolt in as far as the wiring goes? if not what needs to be done?
I'm new at working on 240's, thanks in advance.
anthony
Old Jan 15, 2003 | 12:37 AM
rudeboy's Avatar
seems like it would be pretty stright foward minus things like tach and speedo..
there is always the little things.
usin the dual cam tranny too?
Old Jan 15, 2003 | 09:20 AM
konseiEva's Avatar
i'm in the midst of a ka24de into a ka24e swap right now (91 into a 89) and the 89 tranny matches up. from what i understand all the ka transmissions are the same.
there are some wiring differences like rude says.
also the power steering pump needs to be relocated to the drivers side of the engine compartment. you'll need a dohc ps reservoir as well. i have a link explaining it but its on my computer at home, i'll post it later. you'll need the 95 ecu and dohc wiring harness too. i read somewhere that the s14 drop requires some additional work but its in the computer area and i cant recall what. i'll look into it.
good luck
-h
Old Jan 15, 2003 | 11:21 AM
morexviit's Avatar
thanks man, i appreciate it. Actually i plan on doing an sr swap soon, but the cars on non-op right now and i wanna do the smog and registering with the ka. i just feel like it would be easier. The motor is already in the car, just needs to be wired up.
Old Jan 15, 2003 | 02:22 PM
Limited240sx's Avatar
Straight foreward swap. Wiring isn't too bad either. You may need a new bracket for the tranny tho.
Old Jan 15, 2003 | 06:50 PM
konseiEva's Avatar
SR20 swap with SOHC ps lines
heres the link i promised that gives details and pics for keeping the SOHC ps system
1991se240sx
Jul 31, 2009 09:58 PM
Indolent
Sep 3, 2006 02:51 PM
Purple240
Mar 18, 2006 01:31 AM
YangpaNemsay
Jul 20, 2004 01:35 PM
