Belt tension
Belt tension
I have a quick question about belt tension.
When I bought my 96 240 the guy who sold it to me said he left the belts a little loose. Every time I shifted my belts screamed. I got under the car tightened the belts. No more screaming when I rev it in neutral but now I get a little squelch when I get around 4k to 4.5k rpm. When I hit 5k rpm in 4th it starts screams like crazy. I just shift into 5th and everything is fine.
I would just tighten a little more but everything feels real tight right now. If I tension the belts too much I could run into problems right?
belts
if the belts are to tight they will began buring, please make sure that ur belts are new and all the bolts are in, i had the same problem some guy who had it befor me didnt have a bolt in the bottome of the altenator, so it would screem when i started the car when the altenater shifted down.
As soon as it stops raining I'm going to check that out. Thanks!
You see thats what I love about this board, people are friendly and I never would have thought to check for missing bolts. It's very possible though. Alot was unwired and unhooked when I got the car.
Either way I'm going to get an extra set of belts to put in the trunk. Can't wait to shift without a squeal.
Re: cool man
Originally posted by Biggamehit
also get a can of belt dressing, it will coat the pulley with lubercant because sometimes the pulleyes get dry.
later
later
