Can anyone help me???
Old Dec 12, 2004 | 07:38 PM
Slidin240's Avatar
I own an automatic '89 240sx and i got the stock ka24e engine and it doesn't want to turn on. I've posted about this before but havent really gotten a good answer on it. Theres gas going in the engine and there is spark but the car doesnt want to turn on. The car cranks over but doesn't turn on. I changed the spark plugs, cables, distributor cap & rotor, new battery and the car still isnt turning on. Can someone PLEASE help me out? Any suggestions or answers will be greatly acknowledged.
Thanxs in advance.
Old Dec 12, 2004 | 08:14 PM
LTSCUDRFT's Avatar
Your neutral safety switch could be bad that is all i can think of, because my 240 used to not start, (it was an auto, I swaped it to a 5-speed) I used to just push the button and it would take forever before it would even try to start. That was before i knew about the safety switch i rigged up a push button to start my car cuz of it, I have to turn the key w/ my left hand (it goes into "strat up mode") and push the button w/ my right hand and it fires up with no problems.
hope this could be of some help to you.
Old Dec 12, 2004 | 08:36 PM
Slidin240's Avatar
my car is auto and its been auto from the dealer so i dont kno if that would help but thanx
Old Dec 13, 2004 | 10:10 AM
Ixolas's Avatar
hmm. I would take it step by step and double check everything no matter how minute it might seem.
1. check electrical. Distributor should be checked then spark plug wires then plugs and plug gaps. If those are all correct ensure the firing order is correct.
2. check fuel. Fuel pump then fuel filter then fuel injectors.
3. check air. Make sure the air intake and filter are clear of deprise. Check the cold air sensors, mass air flow sensor. And ensure the throttle bottle valve is opening to get the air/fuel mixture into the intake plenum.
If all of this is in working order than you might need to go into the engine a little to check the vavles, and timing chain. Hope this is helpfull to you. Let me know if it doesn't.
Old Dec 13, 2004 | 10:28 AM
4984 5fsdskfvjdsntr4's Avatar
Banned
Well he said its getting fuel and spark, so those r out of it. I would check the MAF, cause if its not reading any airgoing threw the maf it wont run.
Do you get any weird/bad noises? Have you checked the computer for error codes ?
EDIT: Also how do u know gas is goin in the engine? Did you pull off the line after the fuel filter? maybe the injectors r frozen or the FPR is messed up.
Old Dec 13, 2004 | 02:22 PM
Slidin240's Avatar
Im checking all the things again just to make sure and i was planning on checking the fuel injectors cus the pump is working but im not too sure if the injectors are working or not. Thanxs guys for the help, ill keep you posted as i go through the process.
Old Dec 13, 2004 | 04:53 PM
Texas240's Avatar
you do have a neutral safety swich, even tho it's an auto. check it out. (there's only 3 sensors on the trans.. c'mon )
if you've shifted it gears when it was parked, put it in park & rock the car a bit, it'll help it 'snap' in. i know it's dumb but... *shrugs* check what you haven't checked eh?
Old Dec 13, 2004 | 04:55 PM
Slidin240's Avatar
Ill try that tonite Thanx
Old Dec 13, 2004 | 07:27 PM
Ixolas's Avatar
If the neutral switch is bad I don't think it woudn't crank would it? But I could be wrong.
Old Dec 13, 2004 | 07:35 PM
Slidin240's Avatar
The car does crank and sometimes it sounds like its about to turn on.
teind firstgen
Feb 11, 2008 02:56 PM
demon_dorifto
May 31, 2005 08:18 AM
Drastik
Feb 12, 2005 12:26 PM
TORONTO240sx
Apr 4, 2004 06:08 PM
I'm with Stupid
Apr 23, 2003 02:28 PM
