car dies...
Old Jul 29, 2004 | 06:59 PM
slo9012Vde's Avatar
car dies...
ok well i did the alternator,
and it still dies after about 10 min just sitting there not moving, and well if it is moving, obviously it dies faster..
SO
now i can eliminate the alternator as a problem source.
it seems that the engine goes into a VERY rough idle, and then sputters and finally dies,
i was thinking volt regulator since its not built into the alternator, and therefor the alternator wouldn't be accepting the charge.
OR
a faulty ground, but i really doubt that because the car dies no matter what.
maybe its the head gasket...?
thanks,
Old Jul 30, 2004 | 09:28 AM
JeromeS13's Avatar
Re: car dies...
SO
OR
thanks,
First of all, the voltage regulator IS built into the alternator. Second, didn't you have the alternator tested before you bought another?
Here's a good idea. Check your ECU for a DC. Goto www.********** and goto the FAQ section.
Sounds like you may have a big vacuum leak, bad injector, bad plug/wires, or a bad MAF.
Old Jul 30, 2004 | 09:44 AM
slo9012Vde's Avatar
sorry, i was told the volt regualtor wasn't in the alternator..
what do i know? i am a nub lol.
it still needed a new alternator anyways, and now atleast i can rule that out.
thanks, i'll try and figure something out with it
Old Aug 2, 2004 | 09:32 PM
slo9012Vde's Avatar
Old Aug 3, 2004 | 04:13 AM
Eviscerator's Avatar
u might have a cloged fuel filter
Old Aug 3, 2004 | 05:03 AM
slo9012Vde's Avatar
butwhy would it be ok for 10 min then die?
Old Aug 11, 2004 | 04:52 PM
go S13's Avatar
Maybe is not the alternator! Could be something else! Check the battery, distributor, and fuel system!
Old Aug 11, 2004 | 06:42 PM
slo9012Vde's Avatar
battery is brand new haha, i took it to the mechanic i work with and he said it has to be a bad refurbish alternator that had paperwork that said it worked.. :-\ hmm haha
i dont work there anymore so its really hard for me to get there to talk to him
Old Aug 11, 2004 | 08:02 PM
dkdeleon's Avatar
check for vacum leaks!!!!!!!!
Old Aug 11, 2004 | 08:29 PM
tallic_red240sx's Avatar
Take your ecu out and test for codes.With the key on and the car not running, get to the back of the ecu amd you'll see a screw.Turn it fully clockwise than back to its counter clockwise position.You can either look at you check engine light to get the codes or the back of your ecu.I think it starts off blinking fast, that would be the first number and the second would be the slow blink.
To me your problem sounds like a leaky injector(check O rings) or a bad throttle position sensor.Somethings causing your car to get to much or not enough fuel.
rpgfan
Jul 31, 2005 02:03 PM
Teh Luckinator
Jun 13, 2005 06:30 PM
smokey240sx
Feb 25, 2005 06:35 PM
chiroke
Oct 28, 2004 09:47 PM
beefcake6681
Jun 30, 2003 03:39 PM
