Car wont even turn over!!
Old Aug 20, 2007 | 01:21 PM
scooz14's Avatar
Hey guys
i just picked up an 89 240sx with about 200k on the body and 100k on the second motor. the body is in really good shape, no rust to be seen. i was told that the motor runs fine but there is an electrical problem with it, everytime you go to start the car, all of the electronics go out.
i first though the battery was dead. i multimetered it and it was 12.35v with the key off.
i then tried to start it by jumping the posts on the starter. it sparked, but did not turn over. this resulted in the same issue as when you go to start the car, no power.
what else should i be looking for??
i read in the service manual that the magnetic thing on the starter may be bad. tonight i am going to pull the starter off and test it.
Matt
Old Aug 20, 2007 | 01:47 PM
LA_phantom_240's Avatar
Uh, the starter is bad. End of story. The solenoid may be bad. If you hear it click, the solenoid is working, but the contacts may be bad. in any case, having a starter rebuilt, or even getting a remanufactured unit isn't too expensive. The worst part about this situation is getting the starter on and off. Otherwise, it is simple. Good luck, mang.
Old Aug 20, 2007 | 01:53 PM
scooz14's Avatar
thats what i was thinking. im pulling it off today as soon as i get home form work. hopefully there is a starter local around here.
Old Aug 20, 2007 | 09:04 PM
scooz14's Avatar
i pulled the starter off today, its a reman unit.
i turned the key to the start position with the starter out, and the car didnt die. im going to autozone after work tomorrow, and hopefully the starter is the problem.
if not i have bigger issues.
Old Aug 20, 2007 | 10:21 PM
if it's a m/t you can always try push staring it. when my battery was dieing i did this a few times until i got the new battery. i got so good at it that the car only needed to move about a foot for me to start it.
it's defiantly not a long term solution but just a trouble shooting tip.
Old Aug 21, 2007 | 01:46 AM
neville610135's Avatar
funny, this same thing happened to me and realized it was the OEM starter i just pulled out. and thats with more than a year of delivery driving, starting it almost 10 times a day. altogether 12 yrs old
Old Aug 21, 2007 | 03:18 PM
scooz14's Avatar
FIXED!!! its alive!!
it runs pretty good too. turns out that the battery cable clamps were bad. i changed them and cleaned up all the connections with a wire wheel. started first try.
240sxDriver
Nov 13, 2006 03:34 PM
racesynergy
Apr 16, 2006 07:01 PM
Chillin240
Oct 28, 2005 09:17 AM
wishicoulddrift
Oct 1, 2004 01:52 PM
