Check Engine Light (quickie for the guru's)
Old Aug 14, 2004 | 01:00 PM
fist's Avatar
How do i reset the CEL?
Old Aug 14, 2004 | 09:30 PM
Unplug the battery overnight, and the ECU.
Could be wrong.
Old Aug 16, 2004 | 06:08 AM
fist's Avatar
where is the ecu for me to unplug it???
sorry i would do a search but im at my girlfriends house which is out in the country and its a 26.4 kbps dialup connection....it took me like 15 mins just to load these forums
i tried unplugging the battery but i only left it unplugged for like five minutes...and i went in the car and pushed the brake...but i'll try it overnight and unplug the ecu but i am just not sure where it is located or what it looks like.
Old Aug 16, 2004 | 09:31 AM
It's in the passenger kick panel. Right by their feet, up againts the shell of the body.
Old Aug 16, 2004 | 11:08 AM
if you completely disconnect the battery (both + and - ) then do you really have to unplug the ECU?
Actually, try this (you still have to remove the ECU, but you don't have to go under the hood):
http://www.ka24development.com/ecu_codes.html
I did this method when I bought my car and it worked... your results may vary
Old Aug 16, 2004 | 11:21 AM
fist's Avatar
awesome thanks guys...i'll have to try it on a weekend im starting my new job today...i'll let you know how it turns out.
-okan
Old Aug 16, 2004 | 11:04 PM
Krazyballa3's Avatar
i had a check engine light.... i did the same thing you did... unplug both + and - for about 5 mins... didnt work... you have to do it for like an hour or overnight.... i did it for overnight and the light was gone... no discconnetion of ecu
Old Aug 17, 2004 | 04:08 PM
fist's Avatar
i still havent had a chance to do anything yet....but i will this weekend...i'll try doing it without the ecu first....im hoping its not an actual problem. thanks again for all your replies.
-okan240
Old Oct 26, 2004 | 01:47 AM
cougar10ag's Avatar
Hey, is a 90 s13 non OBD, or OBD0. i noticed there is no CEL on the dash, and my motor seems to misfire a bit so i was wondering how i would know without a CEL. thanks
Old Nov 6, 2004 | 05:09 PM
smokey240sx's Avatar
shouldn't you check what cause the light to turn on in the first place? sorry im not much help.
Old Nov 7, 2004 | 10:13 AM
Your ECU doesn't have a status light?
Old Nov 7, 2004 | 05:34 PM
Project Cheap13's Avatar
The SOHC depends on the emissions system you have ( federal or cali) I dont have a CEL either , so you have to actually look on the ECU itself.
So for future reference
CALIFORNIA emissions= CEL
Federal emissions=NO CEL( manual check of the ECU)
Old Nov 7, 2004 | 11:19 PM
cougar10ag's Avatar
ahh ok. so i gotta check the ECU.. if theres any problems it will flash or be continuously lit?
kenjimatic
Mar 3, 2008 09:05 AM
YamaDRFT
Jul 14, 2004 01:34 PM
89s13drifter
Apr 7, 2004 06:34 AM
Sizzzoooo
Mar 26, 2004 01:30 PM
ProricanRacer
Jan 21, 2004 06:13 PM
