Clutch pedal problem
Old Aug 3, 2005 | 06:44 PM
unit77's Avatar
When I first bought my sons 92 240sx,I was turning around and the tranny didnt want to go into reverse...I placed the edge of my shoe under the pedal and 'seemed' to pull it up a couple of inches.....I never was sure if I was actually pushing the pedal all the way down,as its much different from my Camaro...anyway,this weekend,while my son was driving,it did this again....now I am positive I pulled the pedal up....clutch cylinder looks new,fluid is full...clutch does/has always felt a little 'mushy' but didnt know if this was normal for these cars.....what do you 'experts' suggest?...:>)
Old Aug 3, 2005 | 06:53 PM
CowboyTurbo's Avatar
try bleeding the system, if that doesn't work I had the same symptoms when my withdrawal lever came off the release bearing... you can check that by getting under the car and pushing the part of the lever on the outside of the tranny bell housing back and forth to see if there's any abnormal movement. Also reach under the master cylinder for the clutch and see if it's wet at all from a leak~ sometimes you can't see it but you'll feel the fluid if it is leaking
Old Aug 4, 2005 | 10:07 AM
unit77's Avatar
Thanks for the suggestions...there is no leak..reservoir was full when I bought the car and still is....the problem only happened twice,over a month apart....I have decided to replace the clutch and all related components...:>)
Bumnah
Mar 24, 2008 01:32 AM
chitodsr
Jan 5, 2008 12:34 PM
x3240racer
Mar 12, 2007 04:17 PM
b0rdin4life
Nov 9, 2005 06:32 PM
Matt_240
Nov 4, 2002 06:22 PM
