custom intake
Are you talking about removing your battery and installing your filter there? If you are then allya gotta do is extend the wires if they don't reach. I don't know for sure, but I don't see any trouble other than if the wires won't reach.....
You can just buy a kit to move the battery from www.summitracing.com or www.heavythrottle.com
DO NOT BUY A BATTERY RELOCATION KIT!!! Much cheaper would be to buy some 4 gauge system wires and run that. And you don't have to move it to the trunk. You can move it to the other side but you will have to buy a smaller battery. If you want to see some instructions on how to do this go to www.********** and under the install they have a custom short ram with all the stock parts used.
Yea no problem but a word of advice with doing this, you are going to need to look for two bigger vaccuum lines so that you can turn your stock pipe over but do you mind an extra 15 bucks?!?! Lol I hope you are not that cheap but the expensive thing about this style intake is you will need a cone fitler but I bet you knew that.
tallic_red240sx
Jul 4, 2004 10:56 PM
