cylinder #2 miss
cylinder #2 miss
ok engines been running really rough and seems to have a lack of power.. changed the plugs wires cap and rotor still having the same problem..so i let the car idle and pulled the injector harness of each injector one at a time.. when i pulled cylinder # 2's injector the motors idle did not change...ok so there a miss.. the spark plug wire is getting spark.. im not sure where to go from here.. any suggestions.. do u think i need a new injector>>??
thanks
thanks
wow some good replys :\ .. im getting a new injector tomorrow..anyone know of a how to for injectors replacements?? haynes dont make a book for the 240..anyone know of a coupany that does???
I had the same thing happen to me. Your best bet would be to pull the rail off, and its a ***** trying to get the injector out. just be careful when you put the new one in to get the O-rings lined up right and not break the plastic on the injector. there should only be 3 10mm bolts holding the rail on, and then just pull striaght up. Check all the other injectors while you have it apart too, because I had to replace 2 of mine. If you have any questions, PM me or catch me on Yahoo messenger...ndogg_10@yahoo.com
thanks for the reply ... im still trying to find a maintance book.. i have a fsm for 93 240sx.. but they dont really explain how to remove and replace things... anyone know if chiltons makes a book??? also what shouls i look for on the other injectors??? and should i get ne o rings for all the injectors??
Dounveeme
16
Jul 10, 2004 01:32 AM
