discussion: is swapping in the N60 maf worth it in autox
lol damn i been wanten them Direzza star specs since they first came out.
im running SM now where im doing decent my car is not up to be running with the sm guys but thats what i get for having a SR lol
hahah yea.. dude it was so funny when i had the guys inspect my car at my auto-x school.. they were like im in between classes.. but def not stock at all with what i had done to the chassis. so EM it was for me.. at the most there was only one other car in my class.
my last scca race there was an Esprit there lol
oh and incase it wasn't obvious from the purchase of the 225/45-17 direzza's, i have decided to stay in STS and will eventually create a "budget build STS 240" thread in here, so future people that don't have much money (like me) can make their 240 competitive in autox.
there will be 2 goals for this car:
1. to make more than 169whp and 170w-ft/lbs of torque (because from EXTENSIVE research this is the most i have ever seen an STS 240 make)
and 2. to be within less than 1 second (on course) of the 2 nationally competing '90 civic si's that run here in phoenix, az.
Performance
- KA24DE ( motor number 5 )
- Holset H1C turbo
- JGS Tools Stage 1 Manifold
- 3" V-band Custom heat wrapped Downpipe
- dsm Bov
- Sr 480cc injectors
- 38mm Tail Wastegate
- ssac fmic
- N60 MAF
- Hallman MBC
- Walbro 255 pump
- NGK copper plugs (gapped to .033)
- Emissions Deleted
- No A/C
- No Power Steering
- Apex'i SafcI
- Apex'i Rev/Speed Meter
- Greddy Full Auto Timer
- Bee-R Power Builder Rev Limiter
- Aem Uego wideband
- Faze water temp gauge
- Faze oil pressure gauge
- Faze boost/vac gauge
- Cop Detector
- Gutted
- Racing Steering wheel
- Euro Clear H4 Headlamps
- 12k HID kit
- OEM 180sx front end
- Metallic Blue Paint
- JIC Flt-A1
- front and rear strut bar
- Hawk Pro Pads
- Brembo Slotted Drilled Rotors
- Energy sway bar bushing kit
- Megan Racing Tension Rods
- Megan Racing Endlinks and Bushings
- Megan Racing Rear Sub-Frame Collars
- 17" ADR wheels
- Slotted drilled rotors
- Falken Azenis RT-615s
- Clutch Master Fx500 Stage 5
- Welded Differential
oh wow dude you have to run in MODIFIED?!?! what mods do you have in your 240 that make you run in that class and not in prepared?
-Dave
but no doubt dave in any street class (excet maybe street mod) you should be able to be very competitive with little to no hp increasing mods
well as i recall vinnie proved a 169whp, but without cams, well in STS you still can't use performance cams (you can however backdate, so 240/248 cams and some SOHC pistons are allowed) so i will be doing that, along with I/H/E and under-drive pulley and light accessory pulleys, and a tune so we will have to see what all of that yields (i have to keep the a/c and the clutch fan), but i am hopin for for close to 180whp
oh and doesn't the KA net about 131whp stock???
