Do I need an o2 sensor with a test pipe?
Re: Do I need an o2 sensor with a test pipe?
Originally posted by bw54867
I want to run a test pipe on my ka24de. Do I need an o2 sensor for it and will there be any problems? Will I need a resistor?
my car is a Canadian 91,ka24de,not sure how many o2 sensors there are,i know theres one for sure on the header and one on the cat
when running a test pipe do i need to plug in the o2 sensor or do i leave it unplugged?
plug it in! they are there for a reason. go to a shop get a 12 1/2" pipe bent with two flanges on it and ask them to weld a o2 sensor bung on the testpipe near the same location the original one was, it's not that hard.
EDIT:
P.S. where are you from in canada?
EDIT:
won't it get wrong readings in a test pipe? since its not heating up?
if you have an exaust leak before the test pipe it will make a difference on how well it reads the exaust gas.
Jedi Mind Gamez
Jul 31, 2004 06:03 PM
meangreen240
Mar 11, 2004 07:46 PM
