drain plug god damnit!!!!!
so my radaitor drain plug is all messed up a screw driver wouldn' turn it so i tried drilling it out and the stupid thing still wouldn't come out. any ideas?
Originally posted by franman s13
make sure your turning it the right way or just drain the coolant by disconecting your lower rad hose but be careful cause it'l be messy
Originally posted by twofotisx
Drilling? I would most definately flush your system to make sure that you don't have any crap floating around in your antifreeze.
Originally posted by kang128
how do you bleed the system!!!
when i have my bleed screw open only steam comes out and the radiator only shoots up coolant
BTW: the bleed screw and the radiator cap are two seperate things. If all you see is steam coming out of the actual bleed screw (on the intake manifold) then that's some mean air pockets you've got in there (= bad)
LOL I picture like a steam train. Hah.
bad because your enigne has a proclivity to overheat. This is after you've drained and flushed your system or during the process? I know that the first time that I did a complete flush and refill on my coolant I forgot to open the bleeder valve when I ran it for a few minutes and the engine temp start to go up high. So I whacked myself over the head with the Chiltons guide, realized I was a moron, ran the car with the bleeder valve open for about 5 min, and then all was done and accounted for.
USMCDrifter
Dec 6, 2007 07:49 AM
flipspeed
Dec 18, 2004 11:24 AM
stbrnd
Oct 22, 2003 06:53 PM
