Engine Codes for 91 KA24DE
21 + Ignition signal circuit 32 * E EGR function 45 * E Injector leak .
http://www.**********/faq/
looks like u got a lot of work to do
~Sunrise
~Sunrise
good point. hmm. for the egr, you can just buy a new one and just replace it, about the ignition.. well if it starts fine, dont worry about it too much. check that ur engine grounds are under 2ohm resistance with an altimeter. using the altimeter, check the fuel injectors to be within 11ohm. anything else, replace the bastard. otherwise they might just have a bad oring. first, take off the fuel rail and check out the injectors, takem out and check orings. make sure they arent all ****ty like, if they are, replace the oring. not too complicated
1)tap on egr valve with a big wrench, it might just be stuck open.. clean it
2)check resistance on engine ground, go the extra step, replace the battery ground, and setup a secondary from battery to strut tower.
3)check injector orings, replace. check injectors to be within 11ohm. anything else, replace.
~Sunrise
.1)tap on egr valve with a big wrench, it might just be stuck open.. clean it
~Sunrise
Unbolted the ECU under the kick panel on the passenger side. Make sure the key is in and on the "on" postition. On the back end of it is a skrew wich you turn with a flat head screw driver. The dummy lights will turn off. Wait a couple of seconds and then turn the skrew back and then the "check engine" light will start flashing "long lights" and "short lights". Longs or 10's and Shorts are 1's. And there ya go.
don't want to sound dumb, but my car dosn't have a check engine light. that i know of...... or do I?
all i see when i look at the console is e-brake, oil, washer fluid, batt, seat belt, gas, doors.... no engine light.
Originally posted by socaly4life
Hey are u sure about that last one of the injector leak? It doesn't come up on that site.
OH, and another thing, where the hell do I START!?!?!?!?!??!
drew935
West Coast/Hawaii
Mar 28, 2004 11:36 PM
