Engine Emergancy
so my car wont start, it will click when i try to turn it over. i just replaced the battery, cleaned the battery connectors, and had the starter coil replaced. the car does start up tho. in the morning it needs a jump start and its fine. later in the day even night it starts up just fine so im only haveing this problem the first time i start it each day. whats wrong???
thanks, corey
thanks, corey
this hapened to me too. I used it about a whole year like this but it got worse. Try starting it many times (truning the key on "Start" many times). if it works, then its the relay for the starter. Replace it and clean the conectors as they be rusty. If you wana try to startr it, there's a single cable to the sarter (not the huge one). it conects to a conector really close in the wiring. disconect it, the shove a good, thick cable on the conector, making sure to make good conection inside. you might need a screwdrive to shove the cable in there. then put the car on "on" position, and put the cable you conected on the + side of the battery. the starter should start, along with the car. You can aslo do it while its off. Try it many times. If it starts every time, then its the relay (About 15$) or if it doesn't the prolly the starter (160$ cheapest). If you're doubtful of your cable conection, then go to the starter following this cable, then you'll see that it conects to a screw with a nut. Remove the nut, the wind the cable there and screw the nut. Then try it again. If it doesn't do anything.... sorry, starter is dead, go get sum $$$.
Dres240
Apr 16, 2009 09:16 PM
Plastic Phork
Mar 14, 2005 03:59 PM
SilviaJai
Sep 23, 2003 07:36 AM
