Engine help
oh god yes lol but im gunna buy a mega squirt ecu and im thinking of making my own wiring harness that way i know whats going where and that all my wires are good and have a proper connection. oh and some one cut the wires to the speed sensor so i am soldering the wires right to the speed sensor and i really dont know what wire goes on what side...so will this hurt the sensor or is it like an electric motor and will it just read everything in reverse?
I can't remember if the speed sensors on our cars are two wire AC reluctors or if they are three wire Hall effect sensors. Is it just two wires or is it three? If it's two you will be ok whatever way, it will still read correctly. If it's three you need to find out which terminals are which...one wire on a hall effect is a 5v reference to the ECU...get it wrong and you could fry it.
It was two guys and I took it out to the strip to test the car out and it does not cut out any more the car ran an 18.80 my first time out and i still think the car is not running properly lol but running none the less. I do believe that it is running rich now i believe this because when i let the car idle for some time it seems like i have to clear out the engine and it backfires a lot when i decelerate. Now i am wondering if this could be because i have no exhaust (i.e. muffler and cat) and the engine is in need of a tune or just a little more back pressure. And or maybe its just me what have some of you guys ran with your stock Ka24e on the strip...
electrical stuff is hard to get right, and time consuming to fix....
