engine knock...what can cause this?
Old Oct 11, 2005 | 12:39 PM
corrupt03's Avatar
Exclamation engine knock...what can cause this?
My 240 recently started to have some pretty loud knocking sound which seems to be coming from the head...i have a KA24E SOHC so supposedly you don't have to adjust the valve lash. also i don't know if it could be that the timing chain might have to be adjusted...also one of my injectors is supposedly leaking but when i took it to a shop when my engine light was on, the guy told me that he was getting the injector leak code because of my intake manifold and said that i just needed to replace the manifold...i just wanted to inform myself before i did anything...any help would be appreciated...
Old Oct 11, 2005 | 02:36 PM
2fast4y0u's Avatar
engine knock can be caused from a lot of things. no oil!
i would just check the timing chain, chain tensioner and also, make sure your injectors arent just clicking real bad.
my injectors starting clicking real loud and i thought it was my motor knocking.
Old Oct 12, 2005 | 12:32 AM
TorqueFreak240's Avatar
yeah pretty much what he said. just one question is it hindering your cars performance at all that you can tell?
Old Oct 12, 2005 | 02:57 AM
FlyingS13's Avatar
Just make sure where the noise exactly came from. It could be piston noise. If your car have an auto tranny, a bad tranny will also make that knocking sound. Just double check where the noise came from.
Old Oct 13, 2005 | 11:06 AM
corrupt03's Avatar
i ran into another problem...how in the hell do you take out the freakin' fuel injectors...is there some kind of tool you need to extract them from the fuel rail??? i spent half an hour just staring at that crap trying to figure it out...any help as always would be apreciated...
Old Oct 13, 2005 | 11:10 AM
corrupt03's Avatar
oh and to reply to the other posts...i get lack of power from the engine,its a manual transmission, the higher the revs, the louder the knock is, and if it were the pistons, i'm thinking it would just be that the timing of the spark on the power stroke is off, therefore it would have to do with the timing which is at factory spec, 15 degrees BDC i think ...again thanks
Old Oct 15, 2005 | 08:37 PM
180sxdrifter's Avatar
i thought factory was 20 degrees?
can anyone confirm pls
Old Oct 15, 2005 | 09:42 PM
BigVinnie's Avatar
SOHC 15degress BTDC
DOHC 20 degress BTDC
Old Oct 17, 2005 | 03:09 AM
dkdeleon's Avatar
if it knocking louder at higher rev it could be your rod bearings.if so i would check them as soon as possible before you spin a bearing.
Old Oct 18, 2005 | 12:05 PM
corrupt03's Avatar
about timing...under the hood is says that the default is at 15 degrees but i have it at 20 but the worst has just happened...my engine ate s--- yesterday...i had to go to mandatory training because of my job yesterday and so i had no choice but to take my car...i can only describe the sound from the engine as the end of its life...anyone know of any places close to los angeles that sells engines for cheap...
Old Oct 18, 2005 | 03:29 PM
BigVinnie's Avatar
Yikes man that is defenitely what caused your engine knocking. To little to late.
http://www.attarco.com/
Major distributor of rebuilt KA's in Cali, hit them up the shipping is pretty cheap, they even refer there own trucking company's.
SuperHatch
Dec 17, 2009 09:56 AM
fast240
Aug 26, 2004 09:41 PM
Traxx2K_1
Apr 16, 2004 07:37 PM
NcTwOfOuRtY
Dec 30, 2003 10:45 AM
