exhaust leak problem
Old Oct 31, 2005 | 05:43 PM
Carparthookup's Avatar
would a exhaust leak cause the engine to run rich?
Old Oct 31, 2005 | 07:40 PM
nsn240's Avatar
no, thats after all the combustion, just gases leaving the engine. Unless there's something really abstract that i'm missing here...
Old Nov 1, 2005 | 03:35 AM
wikd240's Avatar
or if the exhaust leak is befor the o2 sensor and diluting the sample... the ecu will not see enough fuel being present and try to correct for it... i would look at a faulty injector or a bad fpr first tho...
Old Nov 1, 2005 | 08:33 AM
does the 02 sensor go bad ezily on the KA24de?
Old Nov 1, 2005 | 09:27 AM
nsn240's Avatar
good call wikd... yea, o2 sensors do go bad, especially if it hasnt been replaced in a long time
Old Nov 1, 2005 | 09:50 AM
any recommendation on which to get? Theres only bosch at autozone and pepboys.
those are like 40 bux and nissan oem one is only 10 bux more
also does anyone know what size wrench i need to remove taht sucker? its hella big and i dont have one that big so i gotta buy a wrench too
Old Nov 1, 2005 | 10:11 AM
240 Freak's Avatar
If the Nissan dealership has them on hand get that, but if you get the non-oem ones just keep the reciept.
Old Nov 1, 2005 | 02:42 PM
wikd240's Avatar
buy the o2 socket... a wrench will in most cases will just strip the old sensor... if you get the nissan one... just go to the parts store and get the right size socket...
Old Nov 1, 2005 | 03:04 PM
nsn240's Avatar
bosch makes good stuff... buy the o2 socket or get an adjustable
Old Nov 1, 2005 | 05:16 PM
BigVinnie's Avatar
Bosch universal you can get for $20.00. Cut the harness off of your old O2 sensor graft it to new sensor, and save $20.00. Get it at PEP boys.....
slidewithpride
Aug 12, 2011 09:51 AM
nschultz0124
Aug 30, 2005 05:50 PM
uvamosk
Aug 12, 2005 07:31 PM
Atown 240
May 2, 2005 01:24 PM
Roscutoo
Feb 2, 2005 11:16 PM
