Gauge install help
Old Apr 10, 2006 | 07:59 PM
mapleridge818's Avatar
Gauge install help
I just bought oil pressure and water temp gauges.
I think I know where to put the senders (oil goes by the oil filter and temp goes in the front of intake right?)
I just want to know if the ecu needs the signal from the stock senders? Can I just remove them and install the autometer ones or do I need to run a tee for them?
It's on a KA24DE if that makes any difference
Thanks!
Old Apr 11, 2006 | 06:08 PM
revolutionz_s13's Avatar
as far as i know, the stock sending units are only for the oil pressure dummy light and the stock water temp gauge. just take them out and put the new sending units in.
Old Apr 11, 2006 | 07:25 PM
LA_phantom_240's Avatar
...i'd leave em in if possible... i hate annoying lights and **** like that. Stealth, young grasshopper, will aid you in success.
Old Apr 11, 2006 | 10:35 PM
re037's Avatar
ecu doesnt need oil pressure switch but itll need the water temp sensor to go into close loop.
if you want the oem warning light run a tee for the oil
indyvang
May 1, 2006 04:44 PM
Flip_240Sex
Mar 1, 2006 05:55 AM
topsecretgold
Aug 4, 2005 10:31 PM
240sxSleeper
May 24, 2005 12:30 PM
Dom
Feb 10, 2002 12:03 AM
