Head Gasket Fitment
What are the difference between the head gasket for a 95 ka24de and the 94 ka24de? The reason I ask is because I blew the head gasket and when I went to buy one at Kragen, they told me the 94 was the same, (95 was not in stock) so I bought it. I also bought the 94 intake gasket as I thought that they'd be the same too but when I filled the radiator with water, it leaked right at the intake manifold gasket, between the manifold and cylinder head. I figured that it was because the 94 and 95 aren't interchangeable so with this discovery I wonder if the same thing will happen with my head gasket. When I examined the old one and the new one I could have sworn that other than the vertical 10mm bolt hole by the distributor, the rest were both identical. Am I going to have to get a 95 gasket or will the 94 work? I did have to trim it a little and make a new hole for that 10mm vertical bolt but it wasn't anywhere near the oil or water passages. I really don't want to tear the engine apart again but I don't want to leave that gasket on there if it won't work. Please help! Thanks!
My engine is running with the 94 gasket. I examined them both, the 95 and the 94 through pics online and they are the same except for that on vertical 10mm bolt. It runs fine though!!
70Challenger
Jun 25, 2006 02:28 PM
