Head swap
Head swap
got a quick question. i have been looking it up and read that if you put a dual cam head on a single cam motor you get better compression. I was wondering if this was true and if i did it would i have to use the single cam computer and wiring or would i have to use the dual cam wiring and computer. thanks in advance for the help
You would have to use KA24DE wiring harness and ECU, also you would have to change the front cover from the KA24E to the KA24DE front cover and you would have to swap out vacuum lines. It's a lot of work and swaping, why not just get new KA24DE and bore it to fit the KA24E pistons? it's about the same amount of work.
i might do that. It isn't for my car. my friend just got a 240 and he wans an N/A build. I want to thank you for the input. Has anyone ever done teh bore or the swap? How much of a gain do you think youd get?
70Challenger
Jun 25, 2006 02:28 PM
revolt-rise
Aug 16, 2005 08:43 PM
