Help Identifying camshaft for 95 ka24de
Recently, I changed my head gasket on my ka24de. I neglected to take notice on which camshaft is the intake and which is the exhaust. Upon close examination, they both look exactly the same save for the fact that one has a green stripe on it and the other yellow. After refering to my fsm and speaking with the local Nissan dealership we were still unable to identify which was which. According to Nissan, the green and yellow do not neccesarily mean anything as each factory using their own markings to identify the cams. Furthermore, the color stripes may have been putted there by the previous owner.
Is there anyone here who has also encountered this situation and is able to shed some light on this matter?
thanks for the help,
Noventa
Noventa
dont just go putting the cams in and seeing what will happen. jeezus... the intake cam- the timming mark lines up the the first lobe. the exhaust cam- the timming mark is offset by 30 degrees. color doesn't mean a thing!
I have a pic of my 95 with the valve cover off. Don't know if it will help at all.
http://www.cardomain.com/memberpage/494710/3
Check it out if you want...
Spddracer
Aug 12, 2004 07:13 PM
