higher compression
we found a gain of 13 hp when going with a set of 10.5:1 pistons... or doing the sohc piston and rod swap...getting the higher 11.0:1 pistons might get you a max of 18... higher compression also means greater ignition control is needed or you will run into detonation problems... and you will have to run the highest grade fuel you can find...
jackyliem
Jun 16, 2005 01:01 PM
onesloweg5
Apr 11, 2005 01:42 PM
