What does 50 lb and 72 lb mean? Can stock ecu handel higher flow injector?
Old Jun 13, 2005 | 12:36 AM
jackyliem's Avatar
well I just found that my fuel injectors is leaking. so I was shopping around for new fuel injector and I found some new JWT injectors for 100 each. Instead of using cc, they use lb to rate. does anybody know what they mean? and if I use higher rate injector, do I need to change mod my ecu? thanks
Old Jun 15, 2005 | 03:17 AM
wikd240's Avatar
the 50 and 72 are pounds per hour... they are low resistance injectors and for them to work in your car yu will need the injector plugs from jwt as well as the resistor pack from jwt... that is just to get them into the car... this is way too much fuel for a stock motor and even a chipped ecu would run real rich... now if you install cams and get a lot of motor work done then you would be okay with the 50 lb/hr units... the 72 lb/hr injectors are for fully built or boosted motors that need a lot of fuel...
Old Jun 15, 2005 | 07:03 AM
Project Cheap13's Avatar
If you are looking for stock replacements. Go to http://www.suncarb.com/
$100 for all 4
Old Jun 16, 2005 | 08:53 AM
jackyliem's Avatar
thanks
Old Jun 16, 2005 | 10:22 AM
BigVinnie's Avatar
Call up RC injectors they can increase your injection size. All they do is ream out the hole at the tips to increase injection they will fix your busted injectors also. Stock injectors are high resistance.
Old Jun 16, 2005 | 01:01 PM
jackyliem's Avatar
I think stock replacment is good enough for me since I don't have any turbo no I am not getting any fuel upgrade yet. thanks for the advise
deputydawg
Dec 26, 2010 11:28 PM
RuizXIII
Jun 16, 2007 01:58 PM
shotty53
May 28, 2005 07:31 PM
KozyNissan
Apr 28, 2004 12:44 PM
Chikara
Feb 25, 2003 08:57 PM
